Running hot
Old Jul 7, 2013 | 12:49 AM
phasevariance's Avatar
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
Running hot
Hi,
92 RS 305 TBI with AC & Electric fan. (Fan only runs with AC on)
It's cooling perfectly fine at idle, however at highway speeds the temp slowly climbs past the halfway mark to almost three quarters.
It seems to spike on hills and is very slow to climb back down. No boiling, heat is working...
Just had exhaust work done, the garage also changed the temp sensor...then this problem started.
Not sure if it's a bad sensor or timing....where to start?
Old Jul 7, 2013 | 12:14 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Ok. Hot on highway not at idle sounds like air damn. Is it still intact? And did they replace the coolant temperature sensor or sender? Sensor for ecm sender for gauge. I've had bad experiences with anything but ac delco on sensors and senders.
The " sensor" they replaced. is it 2 wire or 1?
Posted from Thirdgen.org App for Android
Old Jul 7, 2013 | 04:17 PM
Engine: 305 & 6.2L
Re: Running hot
Air dam is intact. The sensor they changed was 2 wire near thermostat housing.
Old Jul 7, 2013 | 06:22 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Do you know why they replaced it?
Old Jul 7, 2013 | 06:28 PM
mcrandrz's Avatar
Car: 1991 camaro rs
That was off topic. Do you have access to an infrared thermometer? If so that could help eliminate dead spots on the radiator.
sometimes if you have a slightly clogged radiator it won't affect idle because your engine isn't under load.
Has your car sat for any amount of time over 2 months? Could have a little rust. Inspect your coolant in both the overflow and radiator.
Old Jul 7, 2013 | 07:29 PM
Engine: 305 & 6.2L
Re: Running hot
The car did sit for a LONG time because the transmission was shot. The coolant is green.
I'll look into a infrared thermometer.
Old Jul 7, 2013 | 09:05 PM
mcrandrz's Avatar
Car: 1991 camaro rs
That would be your best friend because you could A. Make sure your gauge is right and B. Make sure your radiator isn't the problem.
Old Jul 12, 2013 | 01:28 AM
Engine: 305 & 6.2L
Re: Running hot
Just got the thermo today. Will try to post results tomorrow.
theshackle
Mar 5, 2017 06:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
