right fan on 92 Camaro z28 still not turning on
Old Jul 8, 2013 | 03:29 PM
z28_5.7_TPI's Avatar
Car: 92 Z28 25TH ANN. CAMARO
Engine: 5.7 350
so my question is is the right fan supposed to come on at a certain temperature or does it only turn on with the AC. I have the dual fan setup but only my left one turns on. at this point I'm thinking my fan does not work.
Old Jul 8, 2013 | 04:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: right fan on 92 Camaro z28 still not turning on
The secondary fan will come on with ac request or at 227f when the cylinder head temp sensor between cylinder 6 & 8 grounds.
Old Jul 8, 2013 | 05:03 PM
Engine: 5.7 350
okay so then maybe I have wiring issues.. My car gets up to 240° and the fan still does not kick on. it can't be the fan motor I just bought it yesterday brand new and replaced it.. is there anything I'm missing or should be looking for...? I will also have to look into the sensor near cylinder head 6 and 8
Old Jul 8, 2013 | 05:06 PM
Engine: 5.7 350
also my car does have all the components for AC .. but my fan clutch is not working..therefore No AC
Old Jul 8, 2013 | 08:43 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
To test sensor remove terminal (wire) and ground it (wire).
Old Jul 8, 2013 | 09:05 PM
my91rsproject's Avatar
Car: 91 camaro rs
Engine: 3.1l v6
Transmission: a weak transmission
Axle/Gears: couldnt tell ya
make sure the circuit is grounded well then take the power wire and put some juice to it. if the fan doesn't come on its broken. if it does come on the switch in the sensor responsible for turning it on is not working correctly. I recently overcame this problem by routing the power strait from my battery to a manual switch in my dash, then routed the power from the switch back into my engine fan. a cheap fix I know but im only 17 with a less than limited budget.
Steven 86IROC-Z
May 24, 2026 04:52 AM
RazorN8
Jan 7, 2022 11:44 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
Fronzizzle
Aug 9, 2015 01:15 PM
