New radiator-fan stuck on
Old Aug 15, 2013 | 05:48 PM
Ginko1's Avatar
My old radiator went out on me during a drive and my engine overheated. I replaced the old radiator with a new one but since ive installed it the fan doesnt turn off unless i turn off the car.
It will kick on as soon as i turn the key, even without the engine being on, and stays on. So as long as power is on, the fan is on. The temp gauge is also stuck since overheating.
Could this be a fried sensor causing the fan to come on or a bad relay switch?
1989 RS 5.0L 305 engine
Thanks!
Old Aug 15, 2013 | 07:11 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: New radiator-fan stuck on
The cooling fan switch is located in the pass. side head in between the #6 and #8 spark plugs.
If you unplug it and the fan keeps going, relay's bad. If you unplug it and fan shuts off, fan switch is bad.
Temp gauge needle may be stuck in the bezel (requiring you to disassemble the bezel to move needle) or temp sending unit went bad. Does the needle move at all under any conditions?
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
HikoriYami
Sep 21, 2015 07:11 PM
steimel94
Sep 20, 2015 12:46 PM
ctoledo0834
Sep 18, 2015 04:16 PM
