confused
Old Aug 16, 2013 | 07:10 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
confused
I notice a steady dripping of coolant coming from the driver's side corner of the radiator support after being driven. After I let the car cool down, no more dripping, and the radiator is still full, coolant recovery bottle is empty (which is normal, got a new one coming in the mail). The car has a 180 Tstat in it and is running just under 220 without the AC on. Both fans are spinning. If the radiator was bad, wouldnt it be dripping all the time?? Could there be an air bubble somewhere in the system?
The radiator support is perfectly dry except in that one corner. Only thing on that side is the upper radiator hose which is dry all the way to the bottom.
I can't figure it out.
Old Aug 16, 2013 | 07:16 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: confused
Sounds like a leak from the coolant recovery system.
Old Aug 16, 2013 | 07:18 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: confused
" Rent " a cooling system pressure tester from Autozone, Oreileys, etc.
The leak will be more prevailant under pressure.
Follow the instructions if there are any.
If not, ask the rep to go over it with you.
It can also test the rad cap.
( edit )
Doh!!!
Even said a new one is on the way!!
Sorry about that!!
Veaceonee's Avatar
Re: confused
On the Driver's side?? Recovery bottle is on the passenger side.
Old Aug 16, 2013 | 08:23 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Re: confused
Depends on where the leak is, could be leaking and running along a seam and dripping on the other side or running along the support to that corner. In any case if it was a hole in the radiator it would be leaking anytime it got warm wouldn't need to get hot.
Old Aug 16, 2013 | 10:14 PM
Veaceonee's Avatar
Re: confused
That is whats weird. It only leaks when hot.
Old Aug 16, 2013 | 11:42 PM
KaI_S's Avatar
Car: 88 Trans am
Re: confused
When is hot, it pressurize the system. It will came out at where it leak even is small.
If you use the leak down tester, you will see the pressure drop depend how worst is the leak.
Recovery tank is empty, couple situation: 1. coolant system has air 2. coolant system is leaking
both situation will keep pulling coolant from the tank to recover the system that is not enough coolant.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
