Remove A/C from V6 Camaro
Old Aug 23, 2013 | 10:33 AM
sonu1975's Avatar
My A/C is not working, actually it has not been working since I got my Camaro in 1998 but I thought now that I would like to get rid of it.
One of the pipe is going from the "little radiator" to the A/C and then another one from A/C to a "box" on the passenger side (arrow pointing in the pic).
Is it alright to just remove the pipe from the box and from the little radiator (to get rid of the A/C) or do I need to do something else ?
What is the function of the "black box" ?
Thanks for the tips !
Attached Thumbnails Remove A/C from V6 Camaro-ac.jpg
Old Aug 23, 2013 | 11:06 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Remove A/C from V6 Camaro
You can disconnect and remove everything. Just tie all the cables out of the way. First thing is to drain the system of any coolant although it probably has little or none left in it. It's illegal to just vent it. You're supposed to have it recovered (a/c shop for example). That's up to you. The 'black box' on the passenger side is where chilled coolant chills the air going in to the car. It can be removed but it's a bit of a pain because some of the bolts are in the engine compartment but sum are up under the dash inside. Not difficult just takes some time. Then you're left with a couple of holes in the firewall. I covered mine with two pieces of sheet metal. It makes the rear plugs on that side MUCH easier to get at.
Old Aug 23, 2013 | 12:14 PM
sonu1975's Avatar
ok, but I was thinking to remove only the A/C pump and the pipes. Do I need to close any remaining holes in the "small radiator" and on the black box or can they be open after I remove the pipes ?
Old Aug 23, 2013 | 03:02 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
You can leave them open. I sealed mine up in case I want to re-use or sell all the parts. Prevents junk getting in.
Old Aug 23, 2013 | 03:34 PM
sonu1975's Avatar
Alright thanks !
Elephantismo
Feb 13, 2019 12:51 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
Lmancha96
Sep 25, 2015 08:11 PM
Night rider327
Sep 16, 2015 02:20 AM
