serpentine belt mods
Old Aug 27, 2013 | 06:23 PM
biglano's Avatar
Car: 89 formula
Transmission: 5 speed
does anyone know if there is anything available to put in my belt routing to take the place of a component that has been removed? something like a dummy pulley to make the belt fit right?
Old Aug 27, 2013 | 07:57 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Re: serpentine belt mods
If you're talking about the smog pump being removed, yes there is. I would have to hunt a bit to find the number but GM offered it and it bolts right in the bracket assembly as I have one on my car but it's been awhile since I did the change. Someone on here may know it by heart but if no one chimes in, I will hunt the number down for you. If it is to replace the AC compressor than I am not sure. I think the description to find it is just "pulley", not smog "pump delete". I assume they don't call it that to be politically correct since Al Gore and all
Old Aug 27, 2013 | 09:45 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
you can just leave the smog pump out and find a shorter belt that fits- GM built a lot of cars and trucks without the smog pump or any kid of an idler pulley there ... Dorman makes an idler pulley that replaces the AC pump- you can get it at any auto parts store.
Old Aug 28, 2013 | 10:35 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Use a string to map out routing and determine the new length of the belt.
Old Aug 29, 2013 | 04:28 AM
biglano's Avatar
Car: 89 formula
I put on the smallest belt that would go on. where it loops around theca, then the tension pulley, it rubs from being too close. at idle it doesn't touch, only when accelerating. I used the string trick a few days ago to get the size for the smallest belt. I will check parts store for a dummy pulley.
Old Aug 29, 2013 | 07:27 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You could also read the tech article, https://www.thirdgen.org/serpentine
Old Aug 29, 2013 | 08:37 PM
biglano's Avatar
Car: 89 formula
that's what I needed. thanks. you guys are the best. the help on here is great.
Old Sep 7, 2013 | 11:19 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You can also search "Firebird Smog Pump Delete" on ebay and pull the delete pulley up. This is the route I went.
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
