help running hot
Old Aug 28, 2013 | 05:58 PM
JLH 86 camaro's Avatar
Car: 1986 camaro Z-28
Transmission: 350 turbo
Axle/Gears: 410
help running hot
I have a 86 camaro with a 350 40 over the temp is running 220 or warmer its got a 195 thermostat and 2 electric fans and the radiator size is 32in long by 18 1/2 tall by 2in thick and I've flushed the radiator out any help would be appreciated thanks
Old Sep 7, 2013 | 11:23 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: help running hot
Assuming you are running a stock set up, the factory fan on our cars doesn't come on until 225*, the second fan on dual fan cars doesn't come on until 235* or so. From what you've mentioned, the car is running right where it's supposed to. If you want to cool it off a little more, change the fan switch to change when the second fan turns on and program the ECM to turn the primary fan on earlier.
Old Sep 8, 2013 | 11:14 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Also, WHEN does it run at these temperatures? sitting? Highway?
If it cools off on the highway to around 195, what you are describing sounds like normal operation.
Old Sep 11, 2013 | 07:32 AM
Axle/Gears: 410
it runs 220 or warmer on the highway sitting it gets about 240.....I just got a new 4 core radiator and a 160 thermostat for it ....and the fans come on when I turn the key on its done that since I got the car
Old Sep 11, 2013 | 07:59 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Air Dam on the car??? This under body part is a major item for the cooling system and by your Posts it sounds like you don't have one.
Old Sep 11, 2013 | 02:51 PM
Axle/Gears: 410
I don't think there is
Old Sep 11, 2013 | 03:57 PM
DJP87Z28's Avatar
If you do not have a Air Dam that is the cause of your
cooling problem...
Old Sep 11, 2013 | 04:05 PM
Keoman's Avatar
https://www.thirdgen.org/overheating
Old Sep 11, 2013 | 11:19 PM
Ozz1967's Avatar
Car: 1984 Trans Am
cooling problem...
With no Air Dam you'll stay cool while tooling around town but run hot on the highway.
theshackle
Mar 5, 2017 06:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
