engine oil cooler, pros & cons?
Old Aug 29, 2013 | 04:27 PM
bison999's Avatar
Car: 1984 Firebird S/E
Engine: 2.8 carbed
Transmission: Warner T5 5 Speed
I keep seeing an engine oil cooler set from Hayden and was curious what can I expect from running one of these? or is it not worth it? Let me know what you guys know or think, id like to make an educate purchase but I decided to ask since I could find anything while searching
Old Aug 29, 2013 | 04:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: engine oil cooler, pros & cons?
Only worth it if your oil is getting too hot to begin with. Too cold of oil tho is also not very good for the motor but can sometimes make more power.
Best cooler setups have a thermostat to hold oil in motor til it becomes too hot then allows it to cool off, closing the tstat once temp is reached
Old Aug 29, 2013 | 04:31 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Not needed if you are running full synthetic oil.
Old Aug 29, 2013 | 04:48 PM
bison999's Avatar
Engine: 2.8 carbed
Well the motor is actually running pretty cool but I plan to turbo it later but I do run royal purple in it.
Old Aug 29, 2013 | 07:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I would run without first when you go turbo and monitor temps. If hot then get a cooler
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
toronto formula
Nov 10, 2015 06:17 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
