Cooling fan switch
Old Oct 17, 2013 | 06:14 PM
pullingz's Avatar
Car: 1987 IrocZ28
Engine: ZZ4 350
Axle/Gears: Australian with 3.73
Cooling fan switch
I have a 1987 iroc with a 350 TPI 5 speed and I'm trying to find out where the cooling fan switch is located. It seams to turn the fan on intermittently I think the cooling fan switch is going I changes the coolant temp sensor located under the throttle body thinking that was it but it hasn't fix the problem so I changed the fan relay but still no luck. Can any one offer any help.
Old Oct 18, 2013 | 01:42 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
Re: Cooling fan switch
I just did a thread on this myself. Located on passenger side of engine, between spark plugs 6 & 8.
Can you help identify this sensor?
Old Oct 19, 2013 | 11:52 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If its not the sensor in the head, check the relay and make sure when you jumper power to the fan from the relay socket it turns on and stays on. Also might check for the grounds at the back of cylinder heads and front passenger side of the block. Make sure the connection at the fan doesn't jiggle.
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
