cooling system mix question.
Old Oct 18, 2013 | 12:25 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I drained my cooling system tonight so that I can refill my system tomorrow with the correct antifreeze before freezing temps hit here in Indiana and iv got a question. Can I run tap water with the prestone extended life I'm going to be putting in. My water goes through a water softener before it hits our taps and iv never seen any buildup from hard water so that's why I'm asking. I know that normally, tap water in the cooling system is a big no no and your suppose to get distilled water but if I can get away with my tap I'll just use it.
Old Oct 19, 2013 | 09:36 AM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: cooling system mix question.
you don't want anything in the water or it will leave deposits as well as making your coolant conductive which will lead to other problems. short term it's probably fine but just get a couple gallons of distilled and do it right the first time.
Old Oct 19, 2013 | 11:47 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I agree short term is probably ok. What do you mean by make the coolant conductive? I was under the impression that nearly every liquid was conductive. I have heard copper head gaskets you have to add a tablet to the coolant, are referring to something like that?
Old Oct 20, 2013 | 09:34 AM
mcquigg's Avatar
Car: 85 T/A
Water isn't conductive in its purist form, the minerals and other things it picks up along the way are what makes the water conductive. You will get what is called electrolysis which will allow deposits to start building inside the system.
Old Oct 20, 2013 | 02:13 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
To help combat this, go to your parts store and get a " sacraficial anode "
Made of zinc and // or magnesium. If you have anything aluminum that comes in contact with the coolant, it would be a good idea.
Just my .02
Old Oct 20, 2013 | 08:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Just my .02
Every engine built early 1980's up will usually have something aluminum touching coolant and I rarely hear of using tablets unless its with copper head gaskets, so, why use a tablet?
Old Oct 20, 2013 | 09:31 PM
Car: '87 Camaro
I never thought about it that way.
My 1st rebuild in '80 had an alumimum intake. In '91 I blew it.
I used tap water to mix with the coolant. There was pitting in some spots & gray looking ashy build up in others.
'99 my bigblock had aluminum intake. I used distilled water & the anode. 2005 sold the body kept the motor. The intake was clean-- no pitz or ash looking stuff.
You have a good point! It very well could be that the distilled water prevented the condition. The anode looked new still.
Old Oct 21, 2013 | 09:20 AM
Tibo's Avatar
Car: 1991 Z28 Vert
as I have understood it, the types of engine coolant used have changed to adapt to the aluminum corroding, such as General Motors Dex Cool.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 28, 2015 02:28 PM
64goatman
Sep 9, 2015 01:09 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
