Heater Hose to Water Pump Fitting
Old Dec 23, 2013 | 07:28 PM
Jdawg's Avatar
Car: 1984 Camaro Z28
Engine: LG4 305/5.0 V8
Hey,
I just got a new heater hose to water pump fitting because the one from my old water pump is stripped and wont come out. I'm having a really hard time screwing the fitting into my new water pump. It goes about half-way and then it doesn't turn by hand anymore, but when I use a wrench it's still really hard to turn. I'm fairly sure I got the right size fitting but I don't want to break the threads.
These are the dimensions of the fitting:
3/4" Hose
1-3/4" Long
1/2" NPT
Does anyone know if this is the right size or have any suggestions as to how to screw it in easier? Will I break the threads?
Old Feb 6, 2014 | 10:16 AM
jrmints1415's Avatar
Car: 1985 Firebird
Engine: 2.8l V6
Transmission: 5 speed manual
Re: Heater Hose to Water Pump Fitting
There will be maybe a half inch of threads still petruding from the pump. Get it as tight as you can and you should be fine!
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
