New Radiator install
Old Dec 28, 2013 | 05:21 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
stock radiator is leaking so I bought a all aluminum replacement from summit. Never changed a radiator before. It looks pretty straight forward. Anything I need to be aware of?
Old Dec 28, 2013 | 06:58 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: New Radiator install
Be Very Careful removing & reconnecting the lines & fittings.
You may want to pre soak them with PB Blaster before removing them.
This is to lower the likelyhood of twisting any lines.
Before you just install it & reattach the lines, test fit it to make sure you do or do not have to trim the rubber isolaters.
Old Dec 29, 2013 | 09:01 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Thanks for the info.
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
LittleFranks
Sep 17, 2015 12:22 PM
theshackle
Aug 22, 2015 06:52 PM
