Quick question about water pump pulley and belts
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
So I have my water pump and alternator going off the same belt and same groove for the crank pulley. The first groove is that for the water pump? Or is that for A/C? I dont have a/c by the way. Is it spinning the water pump slower the way I have it routed? It's a dumb question I know...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Quick question about water pump pulley and belts
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Non-A/C V-belt setup should have one belt that goes from the crankshaft to the water pump and alternator. Another belt goes from the crankshaft to the water pump to the power steering pump. Finally there is a belt that runs from the water pump to the air injection pump.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Aug 12, 2015 11:33 AM
