HELP! Install A/C unit from scratch
Old Feb 27, 2014 | 10:02 AM
KDot's Avatar
Car: 84 Camaro Z28
Engine: 350 carb
Axle/Gears: Stock
Purchase a 84 Camaro (v8, 5.0) w/o the a/c unit in it. Texas summer is coming up and I need to put a new on in. Need instructions on how to install everything, then I will have a shop recharge it. As of now every shop is charging $800+ to install/recharge. I can get that price below $200 if I can install the parts myself. This is where I'm currently at:
Parts I got:
• A/C Compressor
• A/C Receiver Drier
• A/C Condenser
• Heater core
• Evaporator core
• Heat/AC Fan motor
• A/C Main Compressor hose
Still in car:
Heater core
Evaporator (and blower).
Any help is appreciated!
Old Feb 27, 2014 | 08:44 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: HELP! Install A/C unit from scratch
i would buy everything related the heating and air from a same year [or close]car and replace the parts that aren't the same.i suspect it will be everything.
Old Feb 27, 2014 | 08:55 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
do you have the engine side of the heater box? i am not 100 percent sure but i know that you need to unbolt the non a/c blower motor housing and replace it with one that will house the blower and ac evap,heater controls will be different as well as vac lines,you will also need the water shut off valve to stop the hot coolant from going into the heater core when using ac
Old Feb 27, 2014 | 10:09 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
You'll need the orifice tube: http://www.autozone.com/autozone/par...mString=search
(just search autozone for your car, but it should be the same)
and you'll need the A/C pressure switch for the fan. Are you converting to R134? If so, you'll need the conversion kit for it. The shop might be willing to do it though. Make sure you flush everything as well. You can buy the A/C flush at Autozone.
Was your car originally set up for A/C? It sounds like it was seeing as the Evap is in the car already.
Old Feb 27, 2014 | 10:24 PM
KDot's Avatar
Car: 84 Camaro Z28
Engine: 350 carb
Axle/Gears: Stock
All the parts I have are from an 86' (except what is still in the 84'). The receiver drier is new. I picked up an orifice tube from AutoZone. The engine side of the heater box is still in the 84'. I want to switch to R134. I'm not familiar w/the water shutoff valve? Also I was told that only a shop can do the flush for me? And yes it was originally set up for A/C.
Thanks for the help so far, please keep it coming!!!
Old Feb 28, 2014 | 06:34 AM
https://www.thirdgen.org/forums/tech...onversion.html
See post #3
Old Feb 28, 2014 | 10:21 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Plus there are many instructional videos on the internet which may help. Production values vary a lot.
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
hectre13
Aug 26, 2015 08:17 AM
