Airflow through intercooler
Old Apr 15, 2014 | 06:48 AM
Jon614z28's Avatar
Car: 1992 Z28 Aniv. Edition
Engine: 5.3 L33 Turbo
Transmission: Tremec T56
Axle/Gears: 3.27 Borg 9Bolt
Hey guys, just curious if anyone was brave enough to cut out the section of the bumper and bumper support between the fog lights is hopes to gain a less restricted air entry for intercooler/radiator. It pretty much increases the inlet 1/3. With some fiberglass work a nice bumper insert can be made to make it a real tidy job. I have 4th gen fans, decent air dam setup ect. , still heats up 220-230 in the summer, before the intercooler it wouldn't get above 180- 190. This is a single 76mm turbo 5.3. So every bit of cooling helps ward of kr and helps keep the power up. Thanks guys.
Old Apr 15, 2014 | 07:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Airflow through intercooler
Thats what most do with camaros. Open up the front grille for flow at speed. Can fit a good cooler in there but turbo cars run hot by nature.
If you havent already, i would add an oil cooler. Def helps keep temps down. Maybe even a small fan behind intercooler to pass flow to rad
I wouldnt mount intercooler on top of rad.
Terrell351
Jun 13, 2021 01:13 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Nervous2
Oct 8, 2015 10:53 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
