Water pump for 355 swap
Old Apr 22, 2014 | 06:24 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Hi All-
I am looking into getting a new water pump for my 355 swap.
Running a L98 short block bored over with Vortec Heads, relatively mild cam.
Looking at 310hp or so...not looking to race but have autocross on the horizon.
What are some good choices for this?
Also, looking to do a serpentine belt system, if that is a factor
Chuck
Old Apr 22, 2014 | 09:42 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Water pump for 355 swap
The factory water pump is more than sufficient for a 355. I run a serpentine conversion on the 355 in my 84 and use a factory pump. No issues in over 5 years. If you do the conversion, get one from an 88 and up donor.
Old Apr 25, 2014 | 01:27 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
When I had to switch to serpentine I bought the Stewart Stage 2 pump. It is counter clockwise rotation for the serpentine set ups. Most people have good reviews on them as well.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
