water pump help please!!!!!
Old Apr 25, 2014 | 07:05 PM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
hey guys so ive had this water pump on my car for a while the last time i redid the front bracketry i had to find a new water pump after buying muiltiple ones that didnt fit and going through my parts i didnt have anything long story short a buddy of mine had one and gave it to me and it fit! i went to get the car out of my pole barn and the pump was seized i thought no big deal ill just order a new one now that i know what it looks like right? wrong,got one from summit and it hits the bracketry,,the only number on the old pump are ph610 sct,i got no clue what it is and i need help i reserved a spot in car show for next thursday,,any help???? thanks guys!!!!!!!
Old Apr 25, 2014 | 07:58 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: water pump help please!!!!!
are you using the 1990 serpentine belt setup or is it something else?If has been retrofitted to earlier v-belt "long"pump,there are two styles of those;1969~75 and ~1976-87:the two are basicly the same except for accessory mounting lug positions.Post a pic if you can
Old Apr 26, 2014 | 12:12 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I had an after market water pump hit a little so I got a grinder and did a little clearance work. Everything has worked great since.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
