Clicking noise right side low??
Old May 16, 2014 | 05:15 PM
FULL-THROTTLE's Avatar
Car: 86 Iroc
Hay guys,
I was working on my ac and found a green wire under the right side of the dash that was cut, so I reconnected it and now When I turn the key off I get a clicking noise, like a electrical motor with a stripped gear, under the dash or maybe in the engine compartment in the right side kick panel. so I cut the green wire that I connected earlier and the clicking stopped???
Any idea's what this is??
Old May 19, 2014 | 06:13 PM
dlinger's Avatar
Car: 1984 Z28 HO
Re: Clicking noise right side low??
We have an 84 with carb. When key is first turned, the carb has a solenoid that clicks for a short time. Don't know if that helps. Maybe somebody else would have an idea if you gave some information about what car you have.
Old May 19, 2014 | 08:49 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
complete your profile . if the car in question is a YUGO it could be the linear framitz , if a AUDI the SAS system , maybe it's KIA then the redundant muffler bearing . what car your asking about might be helpful . hope it's not a YUGO . good luck .
Old May 24, 2014 | 09:20 AM
Car: 86 Iroc
Sorry about that, 86 Iroc.
Old May 24, 2014 | 10:16 AM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
That's probably your power antenna motor. Most likely someone cut the power wire when the plastic broke inside the antenna.
Old May 24, 2014 | 10:59 AM
power antenna motor
Pretty common actually
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BlackBoulder
Aug 11, 2015 11:15 PM
