86 trans am ac compressor
Old May 16, 2014 | 07:15 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Just bought a very clean 86 trans am. One thing the seller told me was the ac (r12) was disabled and he rerouted the belt off the compressor. He said it needs to be converted. Now being in texas..
Can I just put the belt on the compressor and add r12?
If I do have to switch. Does that mean new compressor or some sort of new setup?
How much would it generally cost?
Would taking it to a free ac check be worth it?
Thanks!
Old May 19, 2014 | 06:50 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 86 trans am ac compressor
Thanks!
you will find it hard to find a EXACT compressor. seems someone thought itd be funny to change the design.i ended up having to buy a re-man compressor in order to have my refrigerant lines attach like OEM. and if you can find it R-12 is best. R-134a in a 12 system never does cool well
Old May 23, 2014 | 01:19 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
None of the shops around town want to charge me 750-1125 to convert this guy to 134a and refuses to servicd an r12 system. I can get r12 pretty cheap maybe just pay someone to reroute the belt to the compressor and see why it was disconnected and go from there.
Old May 23, 2014 | 05:27 PM
Car: 86 IROC
Engine: 5.0 TPI
yeah ,there are a lot of pu$$y shops who either dont know what their doing or are just stupid.you dont want to spend your hard earned money there anyway.get some R-12 and a gauge set and have at it. it really is not that hard. good luck
Old Jun 3, 2014 | 07:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
There's no rerouting the belt,it has it own belt.
Old Jun 3, 2014 | 08:12 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Well found a shop I always use just forgot about while im in town. Quoted 185 for retro fit and system filled.
Old Jul 1, 2014 | 11:53 AM
mantaguy's Avatar
Engine: 5.0 EFI
Could you tell me the number that appears on the Harrison label on your compressor.I would really appreciate it.
evilstuie
Apr 14, 2016 08:52 PM
soarestransam
Sep 1, 2015 04:00 PM
TheExaminer
Aug 25, 2015 07:34 PM
zayne0
Aug 24, 2015 07:22 PM
rh76camaro
Aug 15, 2015 12:48 PM
