hope this is easy
Old Jun 17, 2014 | 05:12 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
hope this is easy
I got a 3.1 to old skool 5.7 carb swap and have everything hooked up on the stock harness (no cuts) the fan wont come on (of course) I think its because I need a CTS. instead of just the 10 fan switch that I do have (soon will be a 180 stat, and a 185 switch in the head. this is the only thing standing between me and sweet driving enjoyment!
I'll do a search (AGAIN) to try to decifer the wire diagrams
Old Jun 18, 2014 | 06:32 AM
Car: 91RS
Re: hope this is easy
I must be missing something simple to be sure somebody has swapped a v6 to a v8 and had to deal with the fan. what I'm going to do when I get home is ground from batt to fan switch connector to see if relay kicks with ign. on, then I'm going to put 12v to the red/black wire in the relay harness. then I'm jumpering the dark green/white to the brown in the relay harness and try to see what the problem is with why it wont kick in automatic
Old Jun 24, 2014 | 08:40 AM
Car: 91RS
http://i1293.photobucket.com/albums/...ps70d7e981.jpg
just in case other ppl have the same quest.
Old Jun 29, 2014 | 03:35 PM
Car: 91RS
jet 60600 fan switch (brand new) isn't working from summit it will not close and connect to ground even with the above diagram. need suggestions on new one?
Old Jun 29, 2014 | 04:09 PM
Car: 91RS
http://www.jegs.com/i/JET-Performanc...d=#moreDetails found this one what do you think?
92-Formula
Dec 12, 2015 10:34 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
armybyrd
Sep 21, 2015 10:28 PM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
