Can't get my radiator cover off!!
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Ok,
The engine has never been cranked in about 2 months -- so that's obviously not the problem ... The cover just won't come out..turned it left , tried to get it thought the grooves...no joy..
Weird. Does this mean it's a bad cap? Bad Radiator?
Chuck
Chuck
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: Can't get my radiator cover off!!
Are you talking about the radiator cap? If so, you usually turn them a small amount then press down and twist them the rest of the way off.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
PUSH DOWN HARD & TWIST.
