Need help to ID a cooling line
Old Jul 17, 2014 | 05:42 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
I noticed I've been losing coolant, and think I found the culprit. There's a hose that connects to the heater bypass valve on one end, then runs down the right front of the block into an aluminum crimper, then it's aluminum and runs under the crank pulley til it gets to a bracket above the oil filter. Where the hose goes into the aluminum crimper and aluminum line, the crimper is split allowing a slow leak. Anyway, is this the oil cooler line? There's also a second line that runs parallel to it and goes from above the oil filter to the radiator, but it's ok. What exactly is it called so I can get a replacement...... L98 motor by the way......
Old Jul 17, 2014 | 05:48 PM
Engine: 5.7L T.P.I.
Re: Need help to ID a cooling line
Here's a pic from underneath near the right front wheel. You are under the motor looking almost straight up. The obviously fatter one is the one that split. The hose clamp attempt didn't work, not strong enough. I did put one on the other hose too to help prevent it from splitting if it was inclined to, but once it's split, no way. Clamp won't work.
Old Jul 18, 2014 | 09:23 PM
Engine: 5.7L T.P.I.
57 views and no one knows what this line is? I realize my description was sloppy, but.....Anyway, the guy at Autozone suggested cracking the rest of the aluminum crimp off and using a hose clamp. Might try that this weekend.
Old Jul 18, 2014 | 09:25 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Oil cooler line.
Old Jul 18, 2014 | 09:47 PM
Engine: 5.7L T.P.I.
Thx. That was what I suspected. Could be that's why I didn't get responses, sort of answered my own question in the OP. I take it the other line is a return line then. Thx for the diagram, those always help.
Old Jul 18, 2014 | 10:06 PM
MY87LT's Avatar
Car: 1987 Camaro LT
You're welcome. Well you have a few choices. You can search the junk yards and get a used line. Internet auction sites for a new or used line. Maybe someone from this board has a spare and is willing to sell or spare it. Or you can send your existing line to a good metal shop that can repair the lines.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
