talking to myself at this point
Old Sep 10, 2014 | 02:05 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
Transmission: 5spd manual
i know this is a dumb question, and with the way my questions have gone unanswered recently im sure i wont get an answer, but i ended up breaking a connector to my diverter and replaced it, after putting so much air in the coolant lines do i have to beeld that out of the system when i add the coolant to replace what was lost and if so how would i go about doing that?
thanks
Old Sep 10, 2014 | 02:14 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
thanks
More or less unless you have an air bleed screw by the thermostat, you would idle the car till the tstat opens, with the rad cap off to push the air into the rad, then keep adding fluid till the rad is full and air bubbles stop appearing and you should be gtg.
Old Sep 10, 2014 | 02:16 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
Re: talking to myself at this point
thanks, thats actully way easier that i figured it would be, so just idle it open and keep putting fluid in, its not gonna build backpressure and spit antifreeze?
Old Sep 10, 2014 | 02:28 PM
willexoIX's Avatar
Its always a possibility so do so with caution. Once it gets warm and the coolant level is almost full, you may get splashing from bubbles still in the system. Safety glasses are a good idea.
After you bleed air, check the rad before you drive for the next couple days cause there will probably still be air bubbles passing through the system for a few days.
Old Sep 10, 2014 | 02:43 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Keep your reservoir tank at its required levels also. Fill to Cold when Cold. And as Willie said, keep an eye on it. It should suck from the res and visa versa.
Old Sep 10, 2014 | 02:50 PM
willexoIX's Avatar
Knew I was forgetting something Bob, thanks. Of course my coolant bottle has been gone for a couple years now so thats probably why, lol.
Old Sep 10, 2014 | 02:53 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
so its done when it gets warm? any other way ill know its all set?, thanks a lot guys, i finally got tired of paying another man to do all my auto repairs when it came to my cars and admittedly im trying to learn more
Old Sep 10, 2014 | 03:11 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Fox.....do you have YOUR coolant reservoir? If so, keep it at its levels and you should be fine.
If not, you can elevate the front of the car while your filling the rad and when the t-stat opens, top off, add and then close er up.
Old Sep 10, 2014 | 03:15 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
yeah i have my res, so it should be ok? i just let it idle with the rad cap off, and it was certainly bubbling for a while, after it got to about 220 i shut it off and it spit a decent amount of coolant right there, so was i supposed to put the cap on first? should i retry it since i lost a bit of fluid there or is it ok?
also now the battery has got a decent amount of coolant on it, how bad is this for it?
Old Sep 10, 2014 | 03:18 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yeah, you shoulda put the cap on before shutdown. Don't try and open it now while its hot!
Top off res, rinse battery off, you be fine!
Just watch it and check it for a few days.
Old Sep 10, 2014 | 03:30 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
thanks a lot guys, ill be keeping an eye on it over the next few days, i topped the resevoir off to hot and i'll check it again everyday, with the amout that spit out it'll still be fine with the res being filled or should i wait till it cools down and run it again with the cap off?
Old Sep 10, 2014 | 04:04 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You're good
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Hill1513
Sep 19, 2015 04:15 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
Out-Cast
Sep 11, 2015 08:03 AM
fasteddi
Sep 10, 2015 09:32 AM
