Bypass heater core
Old Jan 15, 2015 | 05:37 PM
806camaro's Avatar
Car: 1990 IROC
Bypass heater core
I'm removing my heater core and A/C. My question is... How do I route the hoses now. I know the one on the radiator needs to be removed and capped off at the radiator. Do I route the other hoses off the water pump to the manifold?
Old Jan 15, 2015 | 05:56 PM
BADSSSTA's Avatar
Car: 1984 Trans Am
Engine: 350ci
Re: Bypass heater core
GOTO THE AUTO STORE AND GET A BYPASS HOSE THAT HAS A 5/8 AND A 3/4 END THEN REMOVE HEATER HOSES TO CORE . SHOULD BE GOOD TO GO .
Old Jan 15, 2015 | 06:51 PM
83HOZ's Avatar
If it's TPI, then all you have to do is remove the U-shaped hose between the intake manifold and the throttle body; cap the nipple on the manifold fitting(although removing the fitting and plugging the hole with an appropriately-threaded pipe plug is better, safer and more permanant); then remove the hose to the radiator(and all other associated heater hoses) and cap the nipple on the radiator. All hoses gone, and you will also have performed a throttle body bypass at the same time.
$750 L98
Feb 1, 2025 02:25 PM
ndndndnd
Sep 28, 2015 08:00 AM
