Stock cooling fans stuck on
Old Mar 14, 2015 | 03:59 PM
GouldyGTR's Avatar
Hi guys
my 85 Trans Am (5.0TPI) has got the fans stuck on.
they start to run as soon as the car is running and never switch off, can someone show me which sensor I need to change to rectify it,
the temp gauge works fine and the car isnt over heating.
The previous owner has removed the AC compressor and piping, would this have an effect on it? if so how can i get around this issue
many Thanks
Jim
Old Mar 14, 2015 | 05:13 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Stock cooling fans stuck on
The plug in this post, https://www.thirdgen.org/forums/cool...ml#post5886885 , the blue wire need to be grounded or, if the plug is still there, put a jumper in it.
Car was originally single fan btw
Old Mar 14, 2015 | 05:58 PM
GouldyGTR's Avatar
Cool thanks man, so im looking for a sensor on the passenger side between the plugs? My air on pipes are removed so nothing to See there
eightsixseven
Dec 16, 2024 01:50 PM
Cameeeero
Sep 18, 2015 04:00 PM
TA8487
Aug 16, 2015 12:21 PM
sreZ28
Aug 14, 2015 07:48 PM
Leggman1
Aug 6, 2015 04:15 AM
