Weiand G Team water pump leaking..
Old Apr 10, 2015 | 11:28 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Hey all, Thanks in advance. So I purchased the Weiand G team water pump for my stroker. It is great and moves the fluid around well and keeps her cool. The problem I am having is when I get in higher rmps (4000-5500) it blows the seal on the back of the pump and squirts like a super soaker. I have taken the back plate off and the casting is true. The plate is true and fits nice. I replaced the gasket several times switching different kinds of gasket shmew seeing if one works better. The first time it happened my hood was off and it scared the poop out of me cause I thought it was a fuel line. So Im wondering if anyone else has had this problem or similar problems and may have some advice. I called summit and asked them but they didnt know nuttin. I am thinking about drilling and tapping another set of holes but for it to blow like that, there has to be some pretty good pressure/resistance. Little engine info. Older 70s 4 bolt block. Dart heads, rmp air gap. Maybe there is some restriction with the heads or intake? Im pretty sure they are all the same or similar... Thanks!
-Dan
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
