dual fans in 1982 Transam
Old 04-18-2015, 04:44 PM
fteufert's Avatar
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
I pulled a dual fan setup from a 2000 Camaro with a 3.8 V-6. When I tried to install it in my 1982, the drivers side fan shroud is hitting the steering box. I need to lower the fans about 3/4 of an inch more.
Are these fans always this close to the steering box?
I planned on keeping my existing 3 core radiator, or do I need to change the radiator to a newer style?
Thanks guys.
Old 04-20-2015, 12:37 AM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: dual fans in 1982 Transam
I use this same style of fan on my 85 with a champion 3 core, it does sit against the steering box but the fans also sit inside the core support on my car. It shouldn't pose any problems but if your fans won't sit all the way down behind your radiator the you may have to slide the fans to the right slightly. Will your fans sit all the way down in the core support? If your not suffering any major cooling issues your existing radiator should work fine. I would recommend a two speed fan control with these as well, here is the one i use with my setup.
armac
09-29-2015 07:06 PM
Kylej68
Exterior Parts Wanted
09-28-2015 10:00 AM
ivan1137
09-23-2015 09:08 AM
Bubbajones_ya
09-14-2015 08:38 PM
scotrans am
09-05-2015 04:26 AM
Quick Reply: dual fans in 1982 Transam
