Need help with water pump
Old May 11, 2015 | 08:36 PM
Dracoheart's Avatar
Car: 1992 Camaro RS
Engine: 350 SBC Vortec
Ok here is my problem. When i bought my 96 Vortec from the junk yard, the yard wanted all resellable parts off of the block before i took it. So that means, water pump, AC compressor, Alternator, and starter. (i was able to sneek out the power steering pump)
Now the fun part. I have already started the conversion to carb but i am trying to find a water pump. The engine still has the brackets that came with it for the alternator and AC compressor so i need to know if i should just buy a water pump for a 96 Suburban or is their a pump made for a Camaro that will work? I know the Suburban had two coolant pipes coming out of the body of the water pump, is it ok to just bypass those?
Old May 15, 2015 | 08:59 AM
Dracoheart's Avatar
Car: 1992 Camaro RS
Re: Need help with water pump
i guess what i should be asking is if a Long snout Camaro pump is the same height as a 96 suburban pump.
Old May 15, 2015 | 10:53 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
you most likely need the long version pump.
if your running a serpentine belt set-up, most likely you'll need a reverse rotation pump.
the look the same from the outside.
if you take your thermostat out, fill it with water, and take the upper radiator hose loose,...start it up,...water should exit the engine/hose. if water comes out of the radiator, you got it backwards.
you can plug the hole tapped for the water pump, you'll need to plug the intake manifold also.
hope this helps some.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
