Trying to get back to factory, is this correct?
Old Jun 7, 2015 | 01:09 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
A few years ago I changed my thermostat to 160 and added a manual toggle switch for my fan... Worst thing I could have done, the car could never warm up properly. I finally got a chance to change it back and my research revealed that a 195 degree thermostat with a duralast sw500 and ac delco PT 308 wire.
The fan isn't coming on until approx 240 degrees (according to the gauge). I am trying to figure out if my fan switch install was successful. Is there any other backup emergency fan switch that exists if the car reaches a certain temp that is kicking in?
It should also be noted that i also replaced the coolant temp sensor in the water neck as well, which is throwing off my trouble shooting, could this have anything to do with anything?
I never remember my temp going even a hair above 220 on the gauge with my old setup and now it is right at 240.
Im just trying to get back to normal.
Is this a factory setup?
Old Jun 7, 2015 | 11:53 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: Trying to get back to factory, is this correct?
i have my fan on all the time (the car came like that) i too have 195 stat
mine sits just a little below 220, and with ac on a little above 220 gets as high as 240.
im going to install a aftermarket temp gauge i never liked the stock stuff
never seemed accurate at all.
Old Jun 8, 2015 | 12:13 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Before you drive yourself CRAZYpickup a laser temp gun and see if the gauge is reading right. The gauge could be off.
Old Jun 8, 2015 | 12:21 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Old Jun 8, 2015 | 02:34 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Originally Posted by gt4373
Lazer!! one of my favorite shop tools. Think a guy can grab one now for 40 bucks or less. When they first came out couldn't touch one for less that 200. I'd get one that goes up to 1200*F
Old Jun 8, 2015 | 02:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
http://www.harborfreight.com/non-con...ing-60725.html
It's a great addition to your tool box.
Old Jun 8, 2015 | 03:00 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
yes! agreed!!
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
fonzie85
Aug 13, 2015 11:50 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
