92 Camaro with overheating problems
Old Jul 25, 2015 | 01:00 PM
kkirch15's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200c
The 92 camaro im looking at has an overheating problem when sitting idle for awhile. They guy says the problem will never go away because its the way the bumper is built. The car does have a 305 from an 86 monte carlo and the radiator and block were just flushed. Anyone know more about this to go along with him or not?
Old Jul 25, 2015 | 09:26 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: 92 Camaro with overheating problems
electric fan single or double ? mech fan? little more info would help and these cars dont over heat cause of the bumper lmao could be wrong pump bad rad cap timing
Old Jul 25, 2015 | 09:33 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
What is your definition of overheating?
Old Jul 25, 2015 | 10:45 PM
kkirch15's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200c
whatever comes stock with a 92 rs. single fan thats all i know.
Old Jul 25, 2015 | 11:57 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The car runs hot...225 is when the fan comes on from the factory. If it's not going in the red, you should be fine.
If the fan comes on when it's supposed to, it should not overheat. some cars with the single fan will overheat slowly with the AC on as the cooling system ages.
Old Jul 26, 2015 | 08:16 AM
kkirch15's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200c
the car has no ac in it
Old Jul 26, 2015 | 08:23 AM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
86 monte carlo had a clutch fan in it I believe. Well my 84 did so I assume its the same for an 86.
Old Jul 26, 2015 | 09:47 AM
kkirch15's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200c
got more details out of him last night and he said it gets up to 200 if youre just letting it run, so it doesnt overheat just runs hot. would running idle at that temp be a problem or cause any damage? he said otherwise the car is set to run at 180
Old Jul 26, 2015 | 10:34 AM
225° is NOT "overheating".
200° is NOT "hot".
"Bumper is built" has NOTHING WHATSOEVER to do with ANYTHING.
"Set to run at 180", along with all the rest, sounds to me like raw unadulterated BS from somebody that basically doesn't have a clue and is just running off at the mouth so they can bask in the glory of hearing their own voice. I'd recommend ignoring EVERY WORD this person utters on the subject, because it's all mumbo-jumbo, misinformation, or outright lies.
Stock, the electric fan in these cars TURNS ON at about 230 - 235°. That means, as far as the factory engineers were concerned, the engine DIDN'T EVEN NEED COOLING AT ALL until that temp. The fan comes on then, and then turns off at 210 - 215°. Now granted, all of us out here know FAR better than they do, how a car is supposed to work; but still...
I'd say about 95% of all "overheating" complaints on this BBS are a combination of (1) not knowing what the system's proper operation is supposed to be in the first place (expecting something other than what the parts are designed to do; (2) a bad radiator cap; and (3) water, usually tap water instead of distilled, instead of the proper antifreeze mix. Most likely, all of the above apply in this case, to go along with the diarrhea of the mouth deal.
Old Jul 26, 2015 | 11:05 AM
kkirch15's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200c
alright thanks for the help thats what i figured he didnt know what he was talking about
mustangman65_79
Sep 1, 2015 03:51 PM
jbd1969
Aug 17, 2015 07:06 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
