Drivers side sensor and sender wires
Car: 86 Z28
Engine: 383 stroker
Transmission: t5
Axle/Gears: factory 10 bolt with 3.23 I believe
Ok guys one more wiring question. I have three wires I'm trying to figure out for my sender , sensor and one a/c wire . one wire is blue , one is green and the last one is a green wire with a white stripe that goes to a duel flat pin connector with a black wire jumped off of it that has one of those factory push on connectors. The factory compressor was replaced with a Sandon which has a single black connector on it . Any info would greatly be appreciated . Thanks Ironhead
Re: Drivers side sensor and sender wires
Green/white stripe is the AC compressor.
Green is the temp gauge sending unit.
Don't know what blue is. Probably would depend on what engine the car came with.
None of them however goes to any sensor AFAIK; that's one class of things you don't have to worry about.
Car: 86 Z28
Engine: 383 stroker
Transmission: t5
86 z28 original motor was just a 305h motor with factory 5 speed and a/c
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
