overheating on freeway
Old Aug 3, 2015 | 09:29 PM
mustangman65_79's Avatar
Car: 1989 Iroc
First time on a long trip yesterday. As i got up to freeway speeds(65+) I noticed my temp slowly increasing. To the point where I hit 260 and I pulled over and opened the hood. The temp quickly came back down, but once I got back on the freeway, it only took 5 minutes to climb back up to 250 from 210.
It got so hot, that my exhaust heated up my gas in my tank to the point of boiling. I think I almost died on a rolling bomb!
So I guess I'm not getting enough air through while at speed, but not sure what to do. No money for an aluminum radiator.
A while ago I thought about making the fake air scoops on top real, and now I think it will need to be done.
Let me add, that it was 106 where I was.
Old Aug 3, 2015 | 10:49 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: overheating on freeway
could be the lower radiator hose sucking flat and restricting coolant flow at highway rpm,but much more likely a missing airdam or a damaged airdam that is folding back at speed is the cause.A bad thermostat that does not open far enough is another possibility.
Old Aug 4, 2015 | 12:40 AM
Car: 1989 Iroc
new t-stat. But doesn't mean it works.
As for this airdam. Have pics? I don't think I have one at all.
Old Aug 4, 2015 | 04:44 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
That is it then. It is a flexible piece of black plastic underneath the car that deflects air up into the radiator. Search air dam on this site you will find a pic.
Old Aug 4, 2015 | 02:08 PM
Car: 1989 Iroc
So I looked up pics for it on google, as I didn't find any on this site. Yup. Not there. So that much be it. It looks so flimsy though. Should I make a stronger one with more of a dam than a flap?
Old Aug 4, 2015 | 02:25 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
http://www.bonanza.com/listings/82-9...MvNhoC2ETw_wcB
That's it. No need to make changes to it. 6 bolts hold it on
Old Aug 4, 2015 | 02:36 PM
Car: 1989 Iroc
so with that can I run freeway 65+ in 100+ deg heat with no OD trans?
Old Aug 4, 2015 | 02:53 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
yup, without it....you blow up. Fans are only good till you reach around 35mph, then the're moot/useless. The deflector deflects air and causes a negative air flow and flows up to the radiator, then through it. Without it, air flows right under the car and out the rear, never reaching the radiator
Old Aug 4, 2015 | 02:58 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Read up on air flow and underbody plastics here> Pay close attention to post #17
https://www.thirdgen.org/forums/body...ative+air+flow
Old Aug 7, 2015 | 09:34 PM
Car: 1989 Iroc
found a car at the junk yard that has all of them. Now just need a chance to get to it.
Old Sep 7, 2015 | 07:44 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Moved to new thread.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
mustangman65_79
Sep 1, 2015 03:51 PM
