Difference between Camaro & Firebird V8 fan shrouds
Old Oct 15, 2015 | 07:34 AM
Fireblood83's Avatar
Car: 82 Trans Am
Engine: 305 ci V8 4-bbl
Transmission: TH200C
Axle/Gears: 10 Bolt/3.23 posi
Hi, I have a 1982 Trans Am. The 82-85 Camaro and Firebird with the LG4 engine use the manual fan. Under the hood both have a slightly different looking upper fan shroud.
Does anybody know if the 82-85 Camaro upper fan shroud fit on a 82-85 Firebird?
Old Oct 15, 2015 | 01:37 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Difference between Camaro & Firebird V8 fan shrouds
Camaro shroud upper will not fit firebird lower half-fan opening is different size:firebirds used 17"fan,camaro 18.5"fan.'82 FB shrouds also had a minor difference from '83-85 FB shrouds in that they have a reinforcement rib ahead of the fan bulge that was removed when AC hoses rerouted for 1983.While on the subject of early third fan shrouds,noticed some non-AC cars only had a finger guard instead of a complete fan shroud.
Old Oct 17, 2015 | 08:15 AM
Car: 82 Trans Am
Thank you for the reply and info!
IWANNAROCAGAIN
51
Mar 10, 2016 07:07 PM
Night rider327
Feb 25, 2016 09:50 AM
Luigytico09
Oct 1, 2015 08:46 AM
okfoz
Sep 22, 2015 03:37 PM
scottmoyer
Sep 20, 2015 11:54 AM
