91 RS 350 Overheating
Old May 7, 2016 | 09:12 PM
ZachSRP's Avatar
New radiator, new thermostat, manual fan switch (only one fan) it overheats after driving anywhere from 10-20 mins even if it's cool outside. Idling and driving, even on the highway it will overheat. What can I try to do? Also the upper rad hose is swollen.
Old May 7, 2016 | 09:43 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Re: 91 RS 350 Overheating
Swap the hose first! Then burp the system.
Are your lower air deflectors missing? That would be my first guess.
Old May 7, 2016 | 10:39 PM
ZachSRP's Avatar
Will do. No but one is missing a little chunk. Also the cover that goes above them is missing.
Old May 7, 2016 | 11:09 PM
ZachSRP's Avatar
Another question, did 91 RS' come stock with a single or dual fan setup? Mine has a single with a shroud. Would switching to a dual fan setup fix my problem?
Old May 8, 2016 | 08:42 AM
Sounds like your upper rad hose is old and soft and you need a new one. Nothing out of the ordinary there.
Define "overheating". You probably have no clue how many people get on here and post THE EXACT SAME THING you did, claiming "overheating" without telling A SINGLE THING about whatever it is the car is ACTUALLY DOING that makes them think that. Things like, what the gauge says, what the temp ACTUALLY IS as measured with an ACTUAL MEASURING INSTRUMENT, and so forth. You can do better than .... those ... people. Which in turn will ACTUALLY enable us to HELP YOU.
Old May 8, 2016 | 08:46 AM
FormulasOnly's Avatar
Car: 1989 Formula 350
Axle/Gears: 3:23
If you upper hose is swollen is your lower hose collapsing ?
Old May 8, 2016 | 12:28 PM
ZachSRP's Avatar
First time I ever took it on a somewhat long drive on the highway and about 5 miles in the gauge was a little past 220. On the way back it was pegged in the red the whole time. I have a new CTS because the gauge didn't work when I bought the car. It wasn't steaming tho but I was still scared. No I didn't verify it with a temp gun I know I need to. Now I'm scared to drive it long at all, it'll get past 220 very quickly on the highway when it's cool out and it never comes down.
Old May 8, 2016 | 12:29 PM
ZachSRP's Avatar
I'll check
Old May 8, 2016 | 12:36 PM
The CTS doesn't work the gauge.
What makes you think it's "overheating"? Just the trim package in the dash?
Lower hose is probably not "collapsing". VERY VERY VERY VERY VERY rare, if not downright impossible, in a properly pressurized cooling system. A problem in a Model T; not so much with any modern car.
Sounds like you just need to replace the upper hose. Sounds like it's rotten and soggy and soft. "Swollen" is pretty much how they fail; they're that, right before they burst.
Replace the temp gauge sending unit while you've got the coolant drained, see if that makes the gauge read something less scary.
Old May 8, 2016 | 01:40 PM
ZachSRP's Avatar
Sorry I meant the temp sending unit. The one on the 1-4 bank. As I'm writing this right now I'm bleeding the system, it has a ton of air bubbles in it. Hopefully that's all it is.
Old May 8, 2016 | 02:12 PM
ZachSRP's Avatar
Just drove it in stop and go driving for about 10-15 mins, it's raining and it's 72F. According to the gauge it was at 220 the whole time until I got a couple blocks from home, it got to about 3/4. I had it idling for about 30 mins when I was bleeding it.
Old May 8, 2016 | 02:33 PM
BrutalGTA's Avatar
Car: 1989 GTA
Did you replace the upper hose? Can you smell it overheating? Can you attach a picture of the lower deflectors and where the piece above is missing? What about the fan shroud, is it intact and fitted to radiator correctly? Maybe a bag or something flew up and covered the radiator due to the missing piece??
Old May 11, 2016 | 06:48 PM
ZachSRP's Avatar
Old May 11, 2016 | 07:19 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You seem to be missing your lower air dam (#18 in attached pic -008) and pretty much all the baffles to assure air is directed through the radiator.
Attached Thumbnails 91 RS 350 Overheating-008.jpg   91 RS 350 Overheating-009.jpg
Old May 11, 2016 | 07:27 PM
BrutalGTA's Avatar
Car: 1989 GTA
I would hit up some junkyards and gather those missing pieces! They are crucial to ensuring proper cooling on these cars. Also, are you loosing any coolant where you have the heater bypassed?
One more thing. Give that poor thing some degreasing under the hood. Lol
Keep us updated
Old May 11, 2016 | 08:36 PM
ZachSRP's Avatar
Keep us updated
I will, thank you. Not loosing any coolant, the heater is actually hooked up. The po had it bypassed in a very wierd way lol. I've been needing to clean it for a long time! Just haven't gotten to it
Old May 11, 2016 | 08:39 PM
ZachSRP's Avatar
Could you post a pic of yours? Is mine okay with the little chunk missing or do I need one new one? Also do I need the cover the connects the nose? Forgot what it was called.
Old May 11, 2016 | 09:02 PM
deadbird's Avatar
Engine: TPI 305/ v6
Despite not owning a camaro, the 'bird radiator baffle is similar... when you look to see your radiator from top down, you should see plastic (similar to attached pic.. #31 in breakdown). The chipped part you show/ask about, is #34
Old May 11, 2016 | 09:17 PM
ZachSRP's Avatar
I think you hopefully just solved my problem for me lol I've never seen that before. Definitely going to get it. Is it hard to put on?
Old May 11, 2016 | 09:34 PM
ZachSRP's Avatar
This is the cover I was talking about. Is this necessary to have for cooling or is it just an accessory?
Old May 12, 2016 | 01:37 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
How is the fan hooked up to the car.
If you get the wires crossed the fan will spin in reverse.
The fan mounted on the inside is a puller fan. It pulls air through the radiator from the front.
Yours looks like its a easy tell because your missing your condenser.
Just slap some paper on the front of the radiator when the fan is running and see if it sticks.
Any way, its happens so take a look.
Old May 12, 2016 | 10:19 AM
ZachSRP's Avatar
I will. Thanks. The condenser is there.
Old May 12, 2016 | 05:50 PM
ZachSRP's Avatar
Put paper in front of the fan and it pulled to the fan. Is this right?? I also degreased but it looks about the same. Lol
Old May 12, 2016 | 06:27 PM
ZachSRP's Avatar
Is this all I need?? What else do I need? What are the 2 pieces on top for?
Old May 12, 2016 | 09:24 PM
deadbird's Avatar
Engine: TPI 305/ v6
The cover is decoration and hides the baffles (ducting, whatever you want to call it) and the hood latch you don't have, too.
If the fan is pulling the paper as Ron stated, yes, it's fine.
The center air dam for a 'bird will technically work but, not for a camaro. The two extra parts are for the t/a / gta gfx pieces.
Camaro air dam... http://www.ebay.com/itm/GM-OEM-Air-D...dRdTvb&vxp=mtr
This is most of the crap your missing... http://www.ebay.com/itm/1985-92-Cama...BXHQfL&vxp=mtr
Old May 12, 2016 | 09:54 PM
ZachSRP's Avatar
thanks so much! Is it hard to install all of it? Is that a good price for everything?
Old May 12, 2016 | 10:14 PM
deadbird's Avatar
Engine: TPI 305/ v6
Install is not tough with basic wrenching skills.
Price.. don't know, I only looked for examples to show you. It's up to to part hunt for yourself.
Compared to a pull a part yard, it's extremely high. If you have a junkyard nearby, that would be the better route as you'd take the parts off and see where they were, to put them back in place on your car.
Most all those parts bolt on with a 10mm socket or wrench.
Old May 24, 2016 | 03:18 PM
ZachSRP's Avatar
Made my own air dam out of a piece of gutter lol it's not long enough but I can tell it already made a difference. I need to get a longer piece. This one is only sticking down about 2 inches. I also installed a new upper rad hose and that made a difference too. Thanks everyone.
Old May 30, 2016 | 06:31 PM
ZachSRP's Avatar
Took off my a/c condenser today thinking that it was maybe my problem. When I had the radiator out I realized how small it was. Do I need to upgrade to a 3 row?? Previous owner said he installed it but I looked it up and it's some cheap piece of junk.
Old May 30, 2016 | 06:41 PM
BrutalGTA's Avatar
Car: 1989 GTA
Kinda looks like it's had some stop leaking through it. Might have clogged it up.
Old May 30, 2016 | 06:56 PM
ZachSRP's Avatar
Do you think I need a 3 row?
Old May 30, 2016 | 07:41 PM
BrutalGTA's Avatar
Car: 1989 GTA
I'd start with all the correct duct work, maybe have it boiled locally. These radiators are bigger than 4th gens and when set up correctly work great in my experience.
Now your radiator does look rather thin.
Have you replaced your water pump? It's a cheap part, could be a part of your problem.
Old May 30, 2016 | 07:54 PM
ZachSRP's Avatar
Water pump seems to be doing great, I don't think that's it
Old Jul 10, 2016 | 10:45 PM
ZachSRP's Avatar
Still having issues. Brand new radiator. Could my fan not be spinning fast enough? Ways to check? I'm thinking about throwing dual fans on it...
Old Jul 14, 2016 | 05:59 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
driving down the highway the car should be pretty cool as its getting a ton of air. Thats how mine is now with my champion 3 core rad.
Its really cool when im driving at a decent speed, heats up when im going slower, ive got my dual fans on a switch under the dash and i flick them on when it get to 200
JamesC
Aug 15, 2016 05:20 PM
peterc005
May 27, 2016 05:36 AM
Fred SS
May 8, 2016 08:12 PM
87FORMULAL98
May 6, 2016 04:43 PM
Wesley Hooper
May 4, 2016 08:58 AM
