Bad Coolant Leak
Old May 26, 2016 | 05:40 PM
evan555222's Avatar
Car: 1991 Firebird
Engine: 3.1L V6 LH0
Axle/Gears: Stock
Bad Coolant Leak
Hello. I drive a 1991 Firebird with a 3.1L V6. Earlier today, the vehicle ran out of coolant. I added more and noticed that the coolant seems to be leaking out of the small hole on the bottom of the flexplate (torque converter?) cover. Where do you guys think this leak could be coming from?
Old May 26, 2016 | 07:04 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Bad Coolant Leak
If it's dry at the top back of the engine , where the intake manifold meets the heads , and if your 100% certain it is coming out of the torque converter cover from the little weep hole at the bottom of the cover , then the most likely candidate is the block plugs (sometimes called "freeze plugs") at the back of the engine (behind the flexplate on the engine side) . If so , The transmission will have to be removed to gain access to replace the leaking plugs . When it happened to mine , I took that as my cue to pop the engine out , throw a fresh gasket kit at it with a timing chain & gears , and all new brass block plugs rather than the cheaper ones that corrode quicker .
Good Luck with it ......
Old May 26, 2016 | 09:36 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Here is where mine was pouring out of. And the lower one had almost rusted through as well.
Attached Thumbnails Bad Coolant Leak-20160124_140537.jpg   Bad Coolant Leak-20160124_142644.jpg
Old May 26, 2016 | 09:44 PM
evan555222's Avatar
Car: 1991 Firebird
Engine: 3.1L V6 LH0
Axle/Gears: Stock
My engine also needs a new rear main seal, so I might go ahead and use this as an excuse to take care of that as well.
Old May 26, 2016 | 09:45 PM
evan555222's Avatar
Car: 1991 Firebird
Engine: 3.1L V6 LH0
Axle/Gears: Stock
Antares: Yeah, I'd say those look pretty bad.
FireBired
Jul 23, 2024 03:39 PM
the breeze
May 22, 2016 06:30 PM
mrestrictrplate
Apr 15, 2016 08:08 AM
Mattkovitch
Mar 19, 2016 11:02 AM
Matthew1
Mar 18, 2016 02:40 PM
