Overheating 305
Old Jul 16, 2017 | 12:00 AM
phasevariance's Avatar
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
Overheating 305
1992 305 V8
Appears to be Overheating.
Parts replaced:
New Radiator
New radiator Cap
New hoses.
Thermostat housing.
New Thermostat
Water Pump.
On the Infared gun i'm getting readings of 160 180F
The Temp sensor and relay have both been replaced..
I am getting readings of 145-180F when the relay for the fan kicks on
The heat guage in the car was going about 3/4s or highter before relay kickin it on.
Old Jul 16, 2017 | 12:20 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Overheating 305
Originally Posted by phasevariance
1992 305 V8
That sounds about right with the stock inaccurate gauge and 235F fan switch
Old Jul 16, 2017 | 08:53 AM
Re: Overheating 305
Sounds like the car is not "overheating" at all. Sounds quite normal in fact.
Replace the temp gauge sending unit; driver's side head, between #1 & #3 spark plugs.
Old Jul 16, 2017 | 01:42 PM
Engine: 305 & 6.2L
Re: Overheating 305
I remember changing something under the manifold between spark plugs and it was a pain in the ***, I thought it was for the fan to kick on at certain temps.
On a side note, this car has only one electric fan. The car does go into the red when going up hills.
It's difficult to tell if it's just a lying gauge.
Old Jul 16, 2017 | 04:46 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Overheating 305
If it's going into the red on the gauge is it also bubbling out the coolant into the overflow tank?
Old Jul 16, 2017 | 05:47 PM
Engine: 305 & 6.2L
Re: Overheating 305
No, no bubbling no steam but the engine does seem hot. I didn't have my infrared gun on me. I really think it's a lying indicator at this point.
I'm gonna run it at idle after I swap out this sending unit sensor.
If I can post video snapshots I will.
Thanks for the response guys!
Old Jul 16, 2017 | 05:50 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Overheating 305
Is your air dam under the front of the car intact and present?
Old Jul 16, 2017 | 08:38 PM
Engine: 305 & 6.2L
Re: Overheating 305
Yes, the air damn is fully intact. I am running these tests with the car in park. I noticed with the AC switched ON the temp gauge stays at or below the 1/2 way mark. But with the AC switched OFF the temp guage will jump all the way up to to 3/4 (close to red line) and then the fan switch will kick on and activate the fan and it will drop almost back to the 1/2 mark.
It's very unnerving to watch. The readings I had tonight were much lower 130-165 F
Should I just install a separate temp gauge? Not sure what's going on here.
Old Jul 16, 2017 | 08:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Overheating 305
The fan is automatically activated with AC on, so your fan system seems to work fine. Perhaps a fan switch that is designed to turn the fan on at a lower temp would be a good plan
Old Jul 16, 2017 | 09:22 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Re: Overheating 305
Mine (87 GTA dual fans) acts the same way. Tons of info right here on tgo dealing with these issues. I've learned these stock gauges are unreliable. Put a aftermarket gauge on temporarily to check against your stock gauges.
Old Jul 16, 2017 | 10:22 PM
Engine: 305 & 6.2L
Re: Overheating 305
I think you hit on something there. I think it's a reasonable explanation. I'll try a lower rated or after market fan switch.
I'll keep you guys posted.
p.s water pump was failing, the old puddle of antifreeze after sitting a bit then finally dripping at ide. It had to go.
Old Jul 17, 2017 | 07:10 AM
Re: Overheating 305
The temp gauge sending unit is on the driver's side. The fan switch is in the pass side head, same hole; which puts it between the #8 & #6 spark plugs.
The temp gauge one is a piece o cake. Right out in the open staring at you. Yours is farkled. Change it out. Your car is not "overheating" and your fan is working fine. Everything is doing what it's supposed to except the gauge.
You have a piece of genuine test equipment telling you one thing, and a "sporty" trim package telling you something else. Which word in the phrase "lying gauge" do you need explained more fully?
Old Jul 17, 2017 | 03:53 PM
Engine: 305 & 6.2L
Re: Overheating 305
Yes, I've already established the fact that the car is not actually overheating. When I was out for a drive the guage was indicating that the car was overheating.
Brought it home, took some readings, posted it here for some good camaro advise. =)
Lets not engage in trolling =)
So we have:
Old Jul 18, 2017 | 07:57 AM
Re: Overheating 305
Nobody is "trolling" anything.
That's EXACTLY what it should do. The REAL temp should climb gently (not really "jump": I hope that's not what yours does) to around 235°, the fan should come on, it should cool the motor down to 210° or so, the fan should shut off, the temp should begin to climb again toward 235°, the fan should come on, ... for as long as the car sits there idling. Until it runs out of gas. 235° is usually somewhere on up toward ¾ of the gauge on these things; and 210° is just a little above half, usually.
Cruising down the road however, there should be enough air forced through the rad to keep the engine at or just below the fan's shut-off temp. It should run pretty close to thermostat temp, which should be 195°: the gauge should then read right at or just a little below the halfway mark.
With the AC on the fan should run constantly, but the fact that the air reaching the rad has already been SIGNIFICANTLY heated by the AC, will usually make the temp higher than the thermostat temp. Shouldn't be ALOT higher, and should reach a point and stabilize; but expect it to be higher. Maybe 5/8 of the gauge just as a rough guide. Then when driving it should drop back down nearer the center of the gauge again, as the forced air flow provides better cooling.
Why? That is, what good would it do? Will it change the temp the engine is REALLY running at?
What's going on here is, your car is working fine. Your gauge actually sounds like it's not too terribly far off. But you can replace the sending unit and make sure it's as "accurate" as it's ever going to be.
This shouldn't be that hard to understand. Go swap out the temp gauge sending unit and see if that makes the stock gauge read any different. If it doesn't, does it really matter? REALLY? If you know what it reads when the car is working right, then you will be able to tell when the car malfunctions; and that's really all it's ever good for anyway. Think of it as being just an "idiot light" in a different shape. It's simply not "accurate" to begin with and never really will be. It's a go/no-go kind of thing, not test equipment.
Old Jul 20, 2017 | 01:47 AM
Engine: 305 & 6.2L
Re: Overheating 305
I swapped out the temp gauge sending unit and now the stock gauges work properly again. (inline with readings)
The good news is that the "farkled" coolant sensor did get a reprieve but his cousin did not.
Thanks sofakingdom for taking the time to respond and help out
I appreciate it, and maybe others will one day find this thread helpful too.
Old Jul 20, 2017 | 06:55 AM
Re: Overheating 305
Out of curiosity, when it goes through the heat up / fan on / cool down / fan off cycle at idle, what are the points on the gauge that each event occurs at? And what indication does it show while cruising?
Old Jul 20, 2017 | 06:21 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Overheating 305
Wait... are you guys serious about 235F being ok operating temp?? Whether factory programmed or not, isnt that a little hot?
Old Jul 20, 2017 | 06:22 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Re: Overheating 305
Unfortunately GM designed these cars to run on the warm side. They didn't have engine longevity in mind.
Old Jul 20, 2017 | 06:25 PM
Re: Overheating 305
Absolutely. Or at least, the upper limit of "normal", at which the cooling system goes to work. It doesn't sit at 235° 100% of the time.
Not really.
I guess that's why cars from the last 30 years or so, that ALL run at temps like that, will go 200,000 miles easily, while cars from the days of "cooler" operating temps, such as from the 50s, had a tough time going 100,000 without needing SERIOUS work. Or part of why, anyway.
Old Jul 20, 2017 | 10:22 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Re: Overheating 305
Yeah I'm sure nothing like crap Quaker State oil or advancements in bearing technology played a part in it. The newer cars I work on daily that All run at 210* or less and most are creeping up on 200k+ miles. Your elevator don't quite make it to the top floor if you say an engine will last longer running at 240* vs 190* or less. Common sense is heat deteriotes everything inside an engine beginning with breaking down oil. That said you don't want an engine running too cool either. You run yours at the 230-240 mark and I will keep mine at the 210.
Old Jul 22, 2017 | 02:54 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Re: Overheating 305
I'm having a similar issue. mine however is leaking at the radiator. I'm ordering an oem replacement. I'm also going to get the new fan switch that turns the fan on at the same temp that the thermostat opens. I never considered that the gauge wasn't correct.
Old Aug 7, 2017 | 03:40 PM
Engine: 305 & 6.2L
Re: Overheating 305
Update:
I changed my thermostat to a 180 (sticks open if it fails). I also picked up a Jet GM fan Switch 60600. The Jet switch is great because I don't have to burn a chip to run cooler.
Now the fan kicks on at 180-185 and shuts off around 170-175. On the dash temp gauge it kicks on about the halfway mark at 220 and when it shuts off it's 1/4 below. The temp gauge is working as good as it gets after changing out the sending unit sensor.
To change out the fan switch sensor (near plug 8) I had to drive up some car ramps which gave me just enough room. Then I drained out all the engine coolant. I also had to use a spark plug socket and a 3/4 wrench to get at the stock temperature fan switch out (Passenger side - it really is the worst possible location on the car imo) it's right UP under the exhaust manifold near the oil dipstick & starter.
I have yet to drive the car because I threw my back out. I'll update again later today.
