i have a carburated converted 92 cam must i have a front cooling shroud spoiler asse
I have a 92 cam rs i added a 350 throttle body changed intakes and carbed it... elec fan cooled ...i do hv a air dam on the car and a 165 thermostst aftermarket radiator big aluminum one ...original elec fan...
the car was baught with things missing.,
the whole front spoiler cooling shroud is not present.
Must I replace it ?
I live in Tn it gets hot here .
it was 77 yesterday and it ran about 190 to 200 I have a good aftermarket temp guage on the car ...new
Must I replace it ?
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Re: i have a carburated converted 92 cam must i have a front cooling shroud spoiler a
Those temps are perfectly fine, as long as it doesn't go over 210 during regular driving then you are fine. Sure do like to creep at stop lights in the summer though
Yesterday it was 77°the temp on a 100 Mi. Trip reached 225..
I turned on the heater and it stayed around 210 220.
I think I will need a shroud by this summer running a.c. etc.
I found a 88 firebird v8 car shroud .
will it fit my cam ?
the guy can't send me a pic
he says it's a 3 pc assembly
your thoughts pls.
and thank you for replying yesterday.
your thoughts pls.
Car: 1991 Camaro RS
Engine: Hot 355ci
Axle/Gears: 4:10
your thoughts pls.
your thoughts pls.
Just found this too http://www.hawksmotorsports.com/camaro-82-92-lower-radiator-air-dam/
There isn't an option for firebird so I'm 95% sure they are the same.
Pretty much everything in front of the rad support on the Firebird is different from the Camaro, with very rare exceptions.
Car: 1991 Camaro RS
Engine: Hot 355ci
Axle/Gears: 4:10
No it is not; although they are somewhat interchangeable.
The core support and stuff like that is the same, but the way the fenders & GFX fit, the nose, etc. is different, and some of the parts interfere between some years & trims.
From what I've seen (haven't seen EVERY POSSIBLE variant though) the Camaro parts are mostly smaller and simpler, especially narrower, and will probably "fit" on most Birds; but may not be as effective on the other car because they leave places uncovered.
