4th gen dual fan amperage
Old Apr 29, 2018 | 06:36 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Am I safe to run both fans on one 30/40a relay? Or will the fan startup draw be too much for the one relay?
Old Apr 29, 2018 | 06:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 4th gen dual fan amperage
I would say no since they got 3 relays from factory for high and low speed use but one per each is how i do it
Old Apr 29, 2018 | 06:47 PM
I don’t think these fans have dual speeds?
Old Apr 29, 2018 | 07:04 PM
It’s easy enough to run a second relay, just thought it would be a lot cleaner with one. Do you run both fans out once? Or are they set to come on at separate times
Old Apr 29, 2018 | 07:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Mine are separate times
Old Apr 29, 2018 | 09:19 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
They do with the factory 3 relay setup. For low speed the fans are wired in series and run on 6 volts. When they go to high speed they are run on separate 12 volt supplies and voltage increases to 12 volts per motor which makes the setup draw 4x the amperage.
I had 2010 Tahoe fans on my Express van. They use higher wattage motors and bigger fan blades than the 4th gen fans. The Tahoe fans drew 10 amps on low and 40 amps on high. Just ballpark, the 4th gens probably draw 7.5 amps on low and 30 amps on high.
Old Apr 29, 2018 | 10:04 PM
Makes sense. Thanks
Old Apr 30, 2018 | 06:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thanks for that. I remember it was like that but didnt know exactly. I wired an s10 ls1 swap like factory a few years ago
Old May 20, 2018 | 06:31 PM
Boom's Avatar
Car: 1986 Iroc
Engine: 383
I would definitely use a separate relay for each fan. You can get higher amperage relays (~70 amps). However, having separate relays is a safety net in case one goes out you still have the other relay/fan working.
BuiltZ28
Apr 20, 2018 07:11 AM
19f0rmula88
Jul 18, 2011 08:19 PM
85_SS
Apr 27, 2006 11:12 AM
aziroc
Jul 19, 2002 02:44 PM
Bort62
Mar 21, 2001 11:56 AM
