Overheating 1987 Camaro 2.8 tpi?
Old Jul 31, 2018 | 10:02 PM
Sean's Garage's Avatar
I have an 87 camaro rs v6 2.8 (I know I wanted a v8 but this is the only one I could find) and it overheated on the drive back from buying it (about an hour and a half in) and then it overheated then we limped it home, found out that all it had in it was water and stop leak -_- so I then flushed it my best but couldn't get all the stop leak out of the radiator, filled it with coolant, and hooked up the fan (not original) correctly, started driving it, eventually it overheated about a month of regular driving later. I now actually have a real temp gauge and I have flushed it again after driving it for a while to break away that stop leak and so now about 95% of the stop leak is out and it has the correct amount of coolant, I also put in a thermostat since it overheated because it literally did not have one where it should be. Now the temp gauge is usually around 190 which is perfectly normal.. Do you think it was the thermostat? I'm still going to put a stronger fan in because I haven't done much super heavy driving, Ive only driven at about an hour at a time since the last time it overheated.. Anyone know what may have made it stay cool?
Old Aug 1, 2018 | 03:19 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Re: Overheating 1987 Camaro 2.8 tpi?
Who knows maybe thermostat was stuck. These little motors can take a lot of heat before they blow a gasket. Make sure you have the air dam below the radiator. If you don't have it, it can overheat.
TLynch911
Jun 27, 2016 06:52 AM
gary87
Sep 16, 2008 04:38 AM
tpi-hearse
Exterior Parts for Sale
104
Jun 18, 2008 11:39 AM
Mr. Trans Am
Aug 7, 2006 10:11 AM
