Voltage drop at idle with AC on.
Old Aug 28, 2018 | 07:59 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I have an 87 Transam 305 TPI. When I have the air on I am getting a voltage drop at idle to about 20 or 11 volts. The voltage goes back to 13 as soon as the car comes off of idle. The alternator and battery check out as OK. I have replaced the blower motor and resistors. It seems like maybe the idle isn't going up like it should when the air is turned on.
My question is what controls this or what else could be causing the voltage to drop.
Any help would be greatly appreciated.
Old Aug 30, 2018 | 06:43 AM
Re: Voltage drop at idle with AC on.
Not enough alternator.
Old Sep 4, 2018 | 05:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Alternative Advice
Sounds like you don’t have a working tach.
Connect one and observe.
If the idle goes below 600 many alts will turn off.
Happy Racing !
Whether It’s A Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
Old Sep 4, 2018 | 11:04 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I have a working tach.The voltage drop only occurs at idle when the idle goes from its cold idle around 750 rpm in drive with foot on brake to the normal 550 rpm. I think the problem is that when you have the air conditioner on the computer is supposed to boost the idle to 750 rpm. My car isn't doing that. What I wonder is if there might be a relay or something not working.
Old Sep 5, 2018 | 02:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
B8 is ac signal wire. I think it goes to the ac high pressure switch.
12v applied rpm goes up 50rpm or so.
ULTM8Z
Jul 5, 2018 01:34 PM
sting
Jan 2, 2005 10:42 AM
