where is the best place to get system voltage from? for a voltage gauge?
Old Apr 22, 2002 | 12:49 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i am putting an additional (hopefully more accurate) voltage gauge in my car. where is the best place to "get" the voltage from?
i am assuming that it is right at the alternator, but i am not sure.
any ideas?
thanks...
-brian
Old Apr 22, 2002 | 03:37 PM
Jza's Avatar
Jza
As close to whatever you want to monitor as possible. The gauges fuse powers several other circuits in the car besides the gauge cluster. Wiring it to that will give a different reading than just to the battery, and obviously is what is monitored from the factory. I have a digital gauge hooked to each. Later, I'll be adding a switch that can toggle pulling the reading from a couple different places.
For you: yeah, the battery or alternator is a good place.
eightsixseven
Dec 16, 2024 01:50 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
bamaboy0323
Aug 15, 2015 07:20 AM
