305 V8 radiator drain plug
Old Sep 2, 2018 | 11:40 PM
3gencam's Avatar
Car: 1984 Sport Coupe
I want to flush out the very old coolant in my 84 Camaro. I think the radiator is the original one and it doesn't leak at all. I don't see any pepcock on the radiator so I can drain it. I crawled under the car and did see a "round dial" (I think) near the bottom of the radiator but it wouldn't turn. Is that what should open so I can drain the radiator? Sorry for what probably is a stupid question to you guys but I need your expertise.
Old Sep 3, 2018 | 09:09 PM
Drew's Avatar
Re: 305 V8 radiator drain plug
If it's the plastic tank radiator, there's a **** at the passenger's lower corner of the radiator. Turn the **** counter clockwise and it should start draining. Sometimes they can get blocked or jammed up. The valve can be removed from the radiator and replaced if it breaks.
Old Sep 3, 2018 | 09:27 PM
3gencam's Avatar
Thanks! Should this plastic valve or **** come all the way out? Who would sell a replacement **** if it breaks - any parts store chain like Autozone should have it?
Also, I was surprised to find out the radiator was plastic. Was that a factory option or did the car originally have a metal radiator?
Old Sep 3, 2018 | 11:09 PM
Drew's Avatar
The end tanks on most stock thirdgen radiators are plastic. Aside from the plastic getting brittle with age and heat cycles, they're just fine.
The **** will only unscrew so far, the end is barbed and snaps into the nut, and the nut snaps into the radiator tank. Dorman offers a replacement with the valve and nut, seals, etc. Should be able to find one at most local chain stores.
Amazon Amazon
Old Sep 4, 2018 | 02:17 AM
3gencam's Avatar
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Awesome! Great information to know before I attempt to unscrew this. Thank you very much!
Wolverine IROC
Feb 26, 2014 11:21 AM
casperlord
May 7, 2009 10:13 AM
Ray87Z
Jul 8, 2003 03:44 PM
FU-Q
Sep 11, 2002 11:22 PM
elevario
Dec 21, 2001 10:33 PM
