radiator drain plug
Old Sep 8, 2002 | 11:30 PM
FU-Q's Avatar
radiator drain plug
i'm having trouble locating the radiator drain plug can anyone help?
Old Sep 9, 2002 | 10:02 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
If your standing in front of the car, look down to your left at the very bottom. It is usually located on the bottom of the radiator on the passanger side. Usually under the hose that goes to the water pump.
Also, if you can't find it still or you can't get it open, just pull the lower radiator hose off and use that to drain it.
Eric
Old Sep 11, 2002 | 04:50 PM
DOOSKI's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
How often do i have to replace the radiator fluid??? when i looked last time the fluid was nice and green, havent replaced for years........is this ok or should i replace?
Old Sep 11, 2002 | 11:22 PM
FU-Q's Avatar
take off the radiator cap and look inside, if you see rust or any kind of build-up its time to flush your whole system, you can find a plastic valve for doing this at any autozone or similer place.
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jlanz55
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
