1992 z28 dual fan car overheating
Old Nov 5, 2018 | 11:18 PM
Jordan92z's Avatar
My 1992 z28 350 has been overheating and I think it has to do with the fans.It is a dual fan car and one fan works but I've never noticed both of them working at once and it tends to overheat in stop and go driving. Don't know much about this problem so any help is appreciated.
Old Nov 6, 2018 | 09:53 AM
Abubaca's Avatar
Re: 1992 z28 dual fan car overheating
I'm pretty sure that second fan only comes on with the air conditioning. Someone might want to double check me on that, but I think that's the case.
....as for overheating, have you replaced any parts of the cooling system recently. If the radiator and/or water pump are original, it's certainly a possibility they are due for replacement. I don't typically suggest throwing money and parts at a problem, but parts do wear out. It's a 26 year old vehicle and it sounds like you want to hang on to it. Sometimes parts that aren't downright broken still do need to be replaced. Also, a coolant flush isn't a bad idea. Get's all that crud out. .....or it may be something as simply as a stuck thermostat. That's an easy fix.....but....again, wouldn't be a bad idea to go through the system and get it running tip top.
Old Nov 6, 2018 | 10:19 AM
Jordan92z's Avatar
Thx for responding I will see if I can try a few of those things and figure it out.
Old Nov 6, 2018 | 02:27 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The fan switch on the passenger head actuates the secondary fan or AC on should as well. If the fan switch was out the AC on should do it, so I'd be checking the secondary fan relay for failure. Follow the wires back from that fan to find it. Oh, and this would be done only after you put 12 volts to the fan to verify that it's not the problem
Old Nov 6, 2018 | 03:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Nov 7, 2018 | 11:27 AM
Jordan92z's Avatar
How hot would the car need to get to be considered overheating? I was told the second fan doesn't even come on until 245F and the primary fan has always worked but idk if I've ever had the hood up when the car was as hot as 245F to even see if the secondary fan works...so maybe the car isn't even overheating and maybe both fans work I'm not even sure.
Old Nov 12, 2018 | 09:05 PM
Alfisti's Avatar
Car: 1986 Contempo Cantara Camaro
Engine: LG4 5.0 V8
Transmission: T5 5 -speed
I would start by jumping the secondary fan to see if it even works. If it does, you should then test the aux fan relay or temp sensor.
But I think the fans are your issue if it only gets hot in stop and go traffic. If it cools properly at speed the rest of your cooling system is working fine. A flush never hurts of course, and a bottle of water wetter might help a bit too.
Old Nov 13, 2018 | 12:11 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
install a larger fan rely..and run both fans at the same time... (this fix has been done and works fine..did my car when it was brand new in 1992 Z28)
tealman92
Jun 8, 2017 08:29 AM
easySPEEDcamaro
Mar 30, 2007 03:26 PM
aziroc
Jul 19, 2002 02:44 PM
