Reinstating A/C using R134A. What pressure to go with.
Old Apr 17, 2019 | 11:26 AM
Doppelganger's Avatar
Car: 1983 Pontiac Trans Am
Engine: 5.0 but about to upgrade.
Hi all, ive bought an A/C kit to replace the old compressor, components and seals on my 83 Trans Am. The compressor says its ready for R134A but im fairly sure it'll need to run at a lower pressure than standard. I know there is a retrofit pressure swtch to deal with this but ive seen somewhere about turning the small adjuster screw on the standard (brand new) pressure switch. Does anybody know what the correct running pressure should be and how much to turn the screw by (ive heard a quarter of a turn) and which way to turn it.
Thanks in advance.
Rob.
Old May 28, 2019 | 04:32 PM
NINĊ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Kept His Kool
When the outdoor temp is 90° the low side pressure should be between 40&55 PSI.
Happy Racing !
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
FireDemonSiC
Apr 30, 2013 10:07 PM
Ward
Jul 21, 2002 08:12 PM
five7kid
Jul 10, 2002 08:12 PM
squirrelybird
Jul 28, 2001 09:54 PM
