87 IROC 350 overheating
Old Apr 26, 2019 | 02:04 AM
gm1390's Avatar
So Im at a loss Im a pretty good mechanic but Im at a loss right now Ive changed the thermostat and upgraded the radiator Ik my cooling fans arent working at the moment previous owner did some wierd wireing but fixing that but now the car over heats wile driving even I. The freeway and open roads it didnt do it before it would clime in temp to just above the half mark and kick back down not it just keeps climbing into the red zone I burped is the system and still over heats and gets hot quick it dosnt go into the reservoir unless I pull the red tab on the radiator cap any HELP WOULD BE AWSOME Im at a loss here and before I take it into an actual shop and spend the money for them to figure it out I want to try and figure it out and save the money
Old Apr 26, 2019 | 05:17 AM
Drew's Avatar
Re: 87 IROC 350 overheating
You mean they still make Lev-R-Vent radiator caps? Huh... Who knew?
Didja check your air dam? Is it still there? Packrat nest between the a/c condenser and radiator? Check for a stuck gauge? Is it actually getting hot, or are you just trusting the gauge that was garbage when new and hasn't improved with age?
Old Apr 26, 2019 | 07:12 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Fix the obvious first.
Look to see if coolant is actually circulating in the radiator; if it isn't, the core is either clogged or the water pump is suspect.
Additionally, the temp gauge itself may be reading incorrectly. Buy or borrow an infrared temp gun and check the engine's actual operating temperature.
Old Apr 26, 2019 | 01:35 PM
gm1390's Avatar
Yes there is flow threw the radiator the temp Gauge is my next suspect thank you ironwill I will try the Infrared temp reader and see also going to put a auto meter temp gage in as well never really trusted dummy stock gauges could it also be a bad thermostat I got from the store bc it wasnt this bad until I changed it?
Old Apr 26, 2019 | 02:47 PM
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Did your air dam fall off?
Sounds dumb, but it can make a big difference.
Old Apr 27, 2019 | 07:56 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
These days, with low-quality 'auto parts store' and ebay parts of questionable origin, anything is possible. After everything else checks out (and you've fixed your cooling fan issue), remove the new thermostat, tie a wire around it, dunk it into a pot of simmering water, and see if it opens.
Old Apr 27, 2019 | 08:20 AM
M G Brewer's Avatar
Car: 1988 IROC-Z
I've had 2 different third gens that didn't have the scoop/air dam under the radiator that caused major overheating problems. Start there first since it's just visual.
Old Apr 27, 2019 | 08:03 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Have you verified that it is actually overheating?
Old Apr 28, 2019 | 09:24 AM
OK so help me understand here. I'm pretty stoooooopid, kinda sssssslllllllllllllowwwwwww, so things are harder for me to wrap both of my brain cells around, than it is for other people smarter than me.
You have a car with a fan that doesn't work, and the temperature seems to climb out of control.
Do I detect a relationship here? Possibly even a cause and an effect? Or is there something complicated I'm overlooking? SURELY it can't be THAT simple?
Fix your forking fan. THEN start worrying about what else might be wrong. If anything.
And get rid of that lever radiator cap. That's a bad idea from the deep past that is well and widely known to be a FAIL. Just get a good quality normal ordinary one.
mjrad
Sep 13, 2008 09:38 PM
project86ta
Sep 13, 2007 08:40 PM
TestyAmoeba
Jun 14, 2004 11:29 PM
Firl
Oct 29, 2003 04:28 PM
zimmer
Mar 5, 2002 12:10 AM
