Best water pump?
Old Jun 23, 2019 | 11:49 AM
RandyNJ's Avatar
Best water pump?
91' 5.7l 350. Water pump needs replacement and I can't seem to find much information on which is recommended. Currently deciding between acdelco, duralast, or gates. I've read Delco uses the lowest bidder. Haven't heard much about duralast and can't find much of anything about gates other than all of their parts being on eBay.
(Not sure if this post is in the right section)
Old Jun 23, 2019 | 10:13 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Best water pump?
I got a Murray for my '98 K1500-marked "assembled in USA from foreign and domestic parts" so far no problems.$50
Old Jun 25, 2019 | 09:40 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I got the "heavy duty" option from advance auto parts for about $40 works great. I think it has a thicker casting and better impeller.
https://shop.advanceautoparts.com/p/...erm=water+pump
Keeps my 350 cool
Old Jun 26, 2019 | 05:46 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Just make sure you get the right one. some motors with serp belts run a reverse rotation pump.
calgutie
Sep 2, 2012 10:45 AM
Untamed Z
Jul 2, 2012 07:29 PM
steriko
Jan 10, 2005 12:44 PM
clemsparks
Nov 18, 2001 07:59 AM
Apone
Oct 22, 2001 08:48 PM
