Code 32 and high temps
Old May 1, 2019 | 03:45 PM
SliceIROCZ's Avatar
Car: 1990 IROC-Z
Engine: 5.0 TBI
Hello all,
i have a ‘90 305 TBI that I have owned since Nov 2018. The car is stock except for an open element filter and Flowmaster cat-back (neither installs by me). I recently moved out of town and have a ~20min commute that is 45-55 mph. I am noticing that the car runs warm 210-220 after driving for about 15 min when it is anything hotter than 75 out. With it being 90 the last few days I have seen temps starting to reach 230 by the end of the drive.
I have ave also started getting a code 32, which I found is an EGR issue. Can these two be related? I’m not running AC during this since it doesn’t blow cold normally. Any thoughts are appreciated
Old May 28, 2019 | 04:33 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hot 2 Trot
Due to the fact your average commute speed is 50 I would check the Air Dam to see if it’s in good condition.
Happy Racing !
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Old Jun 26, 2019 | 05:48 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Re: Code 32 and high temps
Yeah, sounds like a missing air dam. The dam is essential for cooling at highway speeds. The fans will handle the cooling when stopped or going slow.
Old Jun 27, 2019 | 05:59 AM
SliceIROCZ's Avatar
Car: 1990 IROC-Z
Engine: 5.0 TBI
So sure enough I was missing an air dam. Thanks previous owner. Installed and now holds at 200-210 on the highway. I still notice a bump in temps when the SES light comes on for the EGR but it stays below 220. I guess EGR is the next project. Thanks all
TransAmGTA88
Aug 12, 2014 01:10 PM
lucky14
Mar 26, 2009 11:17 PM
Zrated83
Mar 25, 2004 01:16 PM
stuart
Nov 5, 2003 11:05 PM
MechCD
Oct 9, 2003 04:33 PM
