a/c condenser wiring-SOLVED
Old Aug 3, 2019 | 04:34 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
I added a fan to the a/c condenser. I want it to come on when I turn the a/c on. cant I just wire the fan power wire to the power wire on the "on switch of the a/c?
Old Aug 3, 2019 | 04:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: a/c condenser wiring
No , you must use a relay to control the fan motor , trying to connect a fan motor (huge current draw) straight to the "on" switch of the AC (only meant to switch a smaller current) will result in the switch being vaporized , perhaps the first time you use it .
Old Aug 3, 2019 | 06:04 PM
Evilokc's Avatar
Engine: tbi 305
I ran it through the relay and its still not working. I have constant batt to terminal 30, 85 in a ground, 86 is hooked up to the a/c switch, and the fan is hooked to 87. the **** is a rotary ****. is that going to make a difference? it doesn't have power in/power out.
Old Aug 3, 2019 | 06:32 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
85 needs (ignition switched) +12v power, the hvac control for A/C grounds 86... you currently have a grounded 85 and 86 terminal.
Old Aug 4, 2019 | 12:57 PM
Evilokc's Avatar
Engine: tbi 305
so I have 85 and 86 reversed?
Old Aug 4, 2019 | 09:38 PM
Evilokc's Avatar
Engine: tbi 305
I ran it today and the fan did come on when the compressor came on. my wiring is good. its nice when stuff works. doesn't happen enough.
grumpygreaseape
Jan 31, 2002 08:45 PM
gwman
Jun 27, 2001 01:36 AM
gruveb
Mar 19, 2001 06:04 PM
Cosmik Debris
Aug 1, 2000 09:12 PM
