Can I use my AC condenser as a tranny cooler?
Old Jul 31, 2000 | 11:34 PM
Cosmik Debris's Avatar
Can I? Anyone kind enough to tell me what I need to do?
Cosmik Debris
Old Aug 1, 2000 | 12:01 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Yeah you can. It wont be that hard. Just run the hoses like a normal trans cooler but to the condensor. Anyways I don't know if it would be that good. It might restrict some pressure. Might make you go slower. But it would definetly cool way better. But I think you would need about 11 or more extra quarts of oil
Chris
91 RS 305 TBI
TEAM Neo blooD
15.3@91.11
Old Aug 1, 2000 | 04:22 PM
Do you disconnect the tranny lines going to the radiator and poke them into the condenser or do you run them in series?
Cosmik Debris
Old Aug 1, 2000 | 06:36 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
hrmm never thought of this one, although i wouldnt reccomend it without checking and being 100% sure, but i think it would restrict too much flow, and wind up starving your tranny...
Old Aug 1, 2000 | 09:12 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Do yourself a favor and buy a B&M supercooler. You'll improve the cooling of the radiator, lose weight from the front end, and have less pressure drop on the transmission line circuit.
Here's my supercooler install page:
http://www.isthq.com/~dan/transcooler.html
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
apie2546
Sep 5, 2015 07:40 PM
